neck through, of cut it of? http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=43624 |
Author: | DennisK [ Tue Jun 10, 2014 1:11 pm ] |
Post subject: | Re: neck through, of cut it of? |
I'd keep it. Bad karma wasting good wood. Don't use sandpaper for any significant shaping work. There are better tools. Rasp, file, chisel, gouge, scraper. I can't see exactly what's wrong with it, so I'm not sure which ones would be best for the job. But if you do change the scale length, make sure the bridge can adjust far enough forward, or that you don't mind losing a fret due to the pickup already being routed. Nice looking guitar ![]() |
Author: | Quine [ Wed Jun 11, 2014 9:26 am ] |
Looks like the tuner holes are too close to the edge. Maybe you could cut the head along the holes and glue on another piece Changing the scale length is harder....is that bridge position set already? If you can't move the bridge, you'll have to cut the neck |
Author: | Bart Guitart [ Wed Jun 11, 2014 12:21 pm ] |
Quine wrote: Looks like the tuner holes are too close to the edge. Maybe you could cut the head along the holes and glue on another piece and this would give me a new straight line to base the shaping of the head upon. The only solid wood around the house is a piece of beech. I don't think that would be a problem. thanks for the tips. |
Author: | twick [ Wed Jun 11, 2014 8:23 pm ] |
I would just reshape the headstock. Even if you have to add some wood, you could easily make that look pretty cool. Nice guitar! |
Author: | Bart Guitart [ Thu Jun 12, 2014 5:44 am ] |
I spend half an hour with a chisel and I think it's going to be fine without cutting pieces off. I'd never used a chisel to make a plane surface before (I'm all for curves) but it seems to be working. |
Author: | theguitarwhisperer [ Thu Jun 12, 2014 3:29 pm ] |
If you had to scarf a whole new headstock on there, it could be done, though. |
Author: | fumblefinger [ Sat Jul 05, 2014 10:24 pm ] |
Just a thought. If you still have some of the wood you used, could you cut the existing one just inboard of the tuner holes and glue a piece back on to shape the way you want? Some dowels would add the necessary cross grain strength. Or for that matter a contrasting piece glued on. Make it look like you meant it to be there. I once drilled through a weapon I was making for someone special. Covered the mistake by inlaying some coins on the side that wasn't supposed to be drilled. For that matter, you could laminate some metal to the back side or even thin out the head, cut a metal piece to contour, and laminate another piece of wood over it. Get creative and it will look great. |
Author: | James T [ Tue Jul 22, 2014 3:52 pm ] |
I'd keep the neck and redo the headstock to suit |
